Results 1 to 4 of 4
Thread: Suction when removing gas cap
    Oct 2013
    US
    There is quite a bit of suction when removing the gas cap to fill up the tank. Is this normal? I removed the gas cap while driving to see if it affected the performance but there was no noticeable difference. any thoughts?
    Tom
    www.onelongtrip.com
    Van Fan foreverly's Avatar
    1987 2WD
    Dec 2012
    ATX
    Re: Suction when removing gas cap
    Totally normal & a could sign that your fuel system is healthy.
    I believe it's pressure (not suction) that's normal. If it runs good, then probably nothing to worry about. Tim
    Hint: When replacing the fuel filter or working on any part of the fuel system, always loosen/remove the fuel cap 1st. The positive pressure that's normally in the fuel tank will create a gas leak while the system is open. Loosening/removing the cap will prevent this (assuming the system is opened at a higher point than the fuel level in the tank).
    Oct 2013
    US
    Thanks guys! That makes me feel better about this. I was looking up all kinds of stuff online and thought maybe I was going to have to take the fuel system apart. Glad to know it's nothing to worry about. Good tip about opening the gas cap too
