Results 1 to 2 of 2
Thread: Coolant leak from Temperature sender.
    Dec 2010
    Rockville, MD
    Hi Everyone,
    I was working on my van today looking for leaks and noticed that there is coolant leaking from the temperature sensor. It has fried up the sensor and connector. Surprisingly it still works and gives me a reading.
    My questions here are. Should I just order a new sensor and find a connector as well?
    Try retorquing the sensor?
    Here is a pic.
    I wanna get this fixed asap due to the importance of this thing!
    Re: Coolant leak from Temperature sender.
    I'd just replace the sending unit. The connector is a standard spade connector available almost everywhere. Tim
