Rough Hot Idle - 1992 2TZ-FE - The Saga of Njordi
Hi Everyone, first task with my new Previa is to figure out why I am having bad idle once hot. I started by taking out the throttle body, EGR, and EGR modulator. Two culprits found.
All the vacuum hoses to the modulator were cracked and/or fully blocked. When taking apart the modulator the filter was completely solid and caked with carbon. I tried cleaning it out but I think it is a total loss. I just ordered a new one (Toyota part number 25870-76010).
The other problem I found was that the intake tube to the throttle body is falling apart and was fully cranked off at what I believe is the crank case vent that connects between the intake hose and the oil fill. It is cracked almost completely off where shown here:
So I ordered a new Dorman intake hose and hopefully that will be sorted (Toyota part number 17881-76050).
The throttle body was really quite clean and the IAC was also smooth and clean. I gave both a thorough cleaning anyway, but I very much doubt either of those are my problem.
Njordi goes into my mechanic on Wednesday for a block test.
Re: Rough Hot Idle - 1992 2TZ-FE - The Saga of Njordi
I found this great thread detailing the EGR modulator: https://www.toyotavantech.com/forum/...ulation-Previa
All the symptoms of a stuck open EGR align with Njordi 's symptoms (bad gas mileage, stalling at idle). Fingers crossed this fixes my issue this weekend.
The stoke is high!!!! Block test came back negative! No blown head gasket (for now). List of things after taking a close look up on the lift and running diagnostics:
- bad mass air flow sensor
- bad coolant temp sensor
- leaking valve cover
- leaking front main seal
- leaking seal on the manual transmission
- super small seeping on the front brake calipers
And that is about it!!! So once I get the idle figured out, I have a few projects, but nothing urgent.
Installed the new intake hose and new EGR modulator. Rechecked all vacuum hoses. And fired up Njordi...
Complete victory. Runs smooth as butter and idles at 800 (or whatever that mark is on the tach). Dead even, easy power, feels WAY better to drive.
Feeling very happy.
Awesome!
I second Tim's assessment; I liked your troubleshooting (and Jonny's, on the EGR operation).
So to summarize: you think the running problems were due to the EGR modulator and a leaky intake hose?
That is correct. If the EGR modulator diaphragm is ruptured, the EGR valve will always be open, leading to a super lean air/fuel mixture and make it impossible for the engine to idle smoothly. The lean mixture causes a very low and inconsistent idle. Similarly, vacuum blockages or leaks cause the EGR system to function inconsistently. Here is the EGR function diagram from the factory manual:
Similarly, the broken intake hose was allowing air to enter the throttle body after the mass airflow meter on the airbox. So the computer has an inaccurate indication of how much air is entering and therefore the air/fuel mixture will again be lean and inconsistent.
- 2
When the modulator diaphragm is ruptured, the modulator unit is unable to create the necessary pressure differential between lower and upper halves for the modulator to function, so it is unable to effect change on the position of the EGR valve diaphragm. A functioning EGR valve is closed by default and most EGR valves work even at our vans' old ages. A faulty EGR valve might stick open, but this doesn't seem like it would happen very often, and a non-functional modulator would not be the cause.
I see that I was wrong there. So maybe my hot idle issue was more related to the leak in my intake hose and not really the EGR modulator. Either way, I am glad to have the EGR system working again and my hot idle is still going great. At least this is one thing off my project list! Thanks @Jonny !
