Page 8 of 8 FirstFirst 12345678
Results 141 to 149 of 149
Thread: Overdrive issues
  1. #141
    toyota van awd 1988
    Jun 2013
    Montreal, Quebec
    Re: Overdrive issues
    Hi all,
    I have a 88 4wd auto transmission. On a cold engine condition, the van goes on OD but automatically disengage for fews second and then going back to OD. When engine warm, never had this issue.
    It looks like kind of hesitation on a cold state to stay on the OD.
    What can cause this downshift, thermo switch issue? It looks that temperature have to do with that situation.
  2. #142
    1985 Toyota Van LE
    Mar 2022
    Carthage MO
    Cool Re: Overdrive issues
    https://swedishcarparts.com/
    Overdrive Solenoid Substitute Repair Volvo 240 740 940 OEM AW 1239928 block off plate
    I have a 1985 Toyota Van that had an over drive problems.
    I purchased this part that was designed by the owner of swedishcarparts in IL.
    basicaly just eliminated the use of the OVD push Button.
    Van Life!
  3. #143
    87 LE 4x4
    Aug 2017
    Baxterville, CO
    Just another happy customer who solved his 87 4wd le overdrive issue by unplugging the thermo switch. This site is an incredible resource, feeling grateful.
  4. #144
    1986 Toyota Van
    Nov 2021
    Oregon
    Probably a dumb question but wouldn't cutting the cord for the solenoid work without installing the block off plate?
  5. #145
    Cutting the cord will prevent OD operation (it needs 12V to open/allow OD). The plate is machined to simulate an activated solenoid. You can also use a Dremel with a cutting wheel to alter the "business end" of the solenoid as shown in the image below:
    Just keep in mind this would not be reversible..... but not sure why you would want to reverse it. Tim
  6. #146
    1986 Toyota Van
    Nov 2021
    Oregon
    Ahh that makes sense. I've got the Volvo one in the mail but now I'm temped to just try this now while I wait for it in the mail...
  7. #147
    1987 4x4 man
    Aug 2016
    marin co., ca
    Anyone have the Volvo part # for the overdrive solenoid that works on the van transmission?
    thanks
  8. #148
    Wouldn't removing the inner o-ring accomplish this as well?
    Maybe that wouldn't provide enough fuid volume. Just a thought.
  9. #149
    Quote Originally Posted by donne13 View Post
    thanks
    It's posted earlier in the thread but I believe the general consensus is that they are no longer available.
