I managed to break the wires off of my oil level sensor connector right at the connector, leaving me looking for ways to fix it. I was able to remove the terminals so I now have a way to repair it but then realized I have the old connector from my JDM engine, that was taken off when they installed it. Then I noticed it only has 2 wires, the yellow with red stripe and the center brown wire. The slot for the third wire, which is yellow with a green stripe on my harness, is plugged on the JDM connector so it was never there.
Anyone know why that might be? Do I even need the 3rd wire? It will be easy enough to replace that missing connector with one from mine so I'm mostly just curious for curiosity's sake.
