Apparently idling with high alternator load is bad
I just lost another alternator and it was in a similar situation as last time. I left the car idling with a heavy load on it - the marine batteries I have in the back of my camper van were running low so I left the engine running while I cooked my breakfast in a 350 watt cooker. The combo of pulling max amps from the alt while the van is stationary seems to be the killer.
Luckily I have an extra alt with me now, but I'd like to fix the one I'm taking out. What goes bad under these conditions, anyway? I don't have a power steering leak - the alt is dry, shiny, and only a few weeks old. The weather here has been cool and dry.
Re: Apparently idling with high alternator load is bad
Wish I could help you Reducto. I'm also looking at making mine a camper mobile. I haven't tackled as much as you have, I don't think, but I'm always curious to what others are doing. I also got a fairly large capacity marine battery in mine. I just have one, but would eventually move it to supporting the stuff happening in the back. I was thinking of putting in a solar panel for most of the charging on that one.
Sorry I couldn't be of more help.
Solar is definitely worth it. I had no problems when I was driving 50+ miles per day every day, but staying in one place for a while kills the battery. A 200 watt panel should help quite a bit. I'd still like to not have to worry about killing the alt, though! They simply shouldn't be dying this easily.
Ok, maybe it isn't the idling, but the fact that I'm draining the 200AH of batteries. It's bad for the batteries anyway, so I guess I'll just watch my usage more carefully until I install some solar.
Many of us are very anxious to hear about your swap! That big alt should solve a lot of problems.
