Oli,
I'm about a year late, but picking up where you left off. I'm a new owner of a JDM '91 LiteAce and am desperate to ditch the OEM 14" rims as they are beat all to hell (must've been quite the curb banger back in the day!)
I've been drawing out a bunch of various sizes of wheel and tire sizes to confirm that I can fit some meatier running gear before I go all in on the litf as well.
Has anyone run anything like these American Racing aftermarket Suzuki wheels?
https://www.amazon.com/gp/product/B0...F7G8DU3K&psc=1
They are 15x7 with the correct lug pattern and hub bore, so that part is fine. They however have a -6mm offset which helps with the fit between wheel arch and the slider, just not sure what else to consider nor if the negative offset (20mm difference inboard from stock) is going to be a problem with brakes or suspension?
Anyone have any input on those particular rims?
I'm thinking of pairing them with 215 or 225/75R15's with 2" or so of lift (which I'm also scouring the board for actionable intel...)
Looking forward to joining the TOYOVan pack!
Mark
