Through TVT friends here and posts on how to remove the instrument cluster, I changed out the dash bulbs to white LEDs, here's a photo attached.
Also I got into the dash to inspect my master cylinder and need some opinions if I should change it out. The brakes seem to grab fine, although they pull to the left when it is pressed hard, but I saw some fluid on the floor mat. It was dark, but it was not the color in the reservoir golden brown. I was contemplating changing out the master, but not 100% if I should. I am not familiar with changing it out, but would be a complete swap and bleed?
I am attaching some pics to this and appreciate any input.
