Hi Hugh,
Sorry I missed your post until now. The fan I put on this radiator was only to combat the heat soak issue. I have it set on a timer (shown earlier in this thread) that runs it for 15 minutes after the van is shut off. This ventilates the engine compartment and keeps the fuel from boiling in the rail (it works well). I also rigged it to a manual on/off switch so I could run it at other times. Although the fan works good for the heat-soak issue, it doesn't seem to help much (if at all) to combat overheating while stopped in traffic on a hot day with my AC on. I would recommend this set-up if you are having a heat soak issue, but don't expect it to help with overheating. Tim
PS: Experiencing overheating problems while sitting in traffic on a hot day with AC on is a pretty typical issue with these vans. If you find a solution to that please share as I'd be thrilled to be able to use my AC in those conditions .
