Results 1 to 7 of 7
Thread: No start. Lights on dash
    86 toyota van LE
    Jan 2017
    santa cruz
    Engine not cranking. Lights on dash, not fusable link, already had that problem. Has my starter failed? Charged up battery, tried jumping... nothing. What do you think?
    (2) 1989 2WD LE VAN Wagons
    Jan 2011
    Re: No start. Lights on dash
    does the starter click? if not probably damaged ignition signal wire (black with yellow stripe) and or voltage drop. If the starter clicks maybe bad starter. Installing an auxiliary relay will resolve the voltage drop.
    86 toyota van LE
    Jan 2017
    santa cruz
    Thank you. That’s a start... no pun intended
    86 toyota van LE
    Jan 2017
    santa cruz
    Should I look for the ignition signal wire under the steering wheel?
    86 toyota van LE
    Jan 2017
    santa cruz
    Great news! I inspected my whole electric pathway to the starter and noticed nothing corroded or wrong along the way. I got underneath and banged on the starter with a hammer while my buddy cranked. It fired right up! And has started every time since! Always excited for a successful solution when it doesn’t cost any money
    Probably starter contacts. If so, this problem will likely come back. Usually cycling the key to the start position over and over will get it to crank but eventually(When your in the worst possible location or situation)it just won't work anymore. They're cheap and easy to replace and here is an article discussing it.
    Forum Newbie Nater's Avatar
    1987 LE 4WD
    Nov 2016
    Seattle, WA
    I just followed that thread to replace my starter contacts. Was such a great and cost-effective solution. Super stoked.
    1987 Toyota Van LE 4WD
    1988 Toyota Truck 4WD
    1988 BMW M5
