Results 1 to 2 of 2
Thread: Cooling system pressure
    1997 Previa all-trac s/c
    Nov 2018
    CO
    I am not getting any pressure in my cooling system. The van warms up properly and the heat works. No overheating but no pressure building on the systrm. I just did the inline filter and black flake mod and I don't seem to be loosing any coolant. I'm confused. Any ideas?
    1997 alltrac
    Dec 2016
    illinois
    Re: Cooling system pressure
    Have you replaced the cap? The same black flakes that result in the high idle when cold also obstruct the reservoir outlet channels at the small black hoses. I would pull the reservoir and clean the outlets and see if that helps.
