Tan Van
I'm sure the new alternator plug will help a lot, especially since you found a previous hack job ...
I just want to add that, once, when I had the exact same issue, ...(the click -- no start -- but, battery is good scenario) (I usually had to jump start the van or use a battery charger/starter to get it to start) ...what we found was a wimpy ground wire from the battery box area to the chassis ... we fabbed up a huge gauge new wire with nice terminals and with thet great new ground, the problem went away ... just in case you have't done this already
