Results 1 to 10 of 10
Thread: Rubber Underneath (suspension parts)
    Van Enthusiast User1's Avatar
    Nov 2011
    Long Beach, CA
    I tried to find something on replacing the rubber underneath the van, but I couldn't find anything. If you want to keep things clean I can delete this and follow up with the thread that's available. If nothing is started already, I'd like to see what's out there to do the replacement. I kinda want to do just about all of the replacing if needed all together.
    A couple of pics are here,
    I believe this is part of a front sway bar on a 87 4x4, all pics are to my 4x4, but I'm betting that this is valid for many other vans here,
    MOD EDIT — These are called front stabilizer cushions. They are part of the stabilizer bar system.
    MOD EDIT — The rubber bumper for the lower A-Arm is: BUMPER, FRONT SPRING, NO.2. The accordion rubber boot is: BOOT, STEERING RACK, NO.2. In the picture below, the drive axle and boot are removed (not visible).
    That's it for now. I'm sure I'll have other pics and questions regarding this .
    Oct 2015
    Walnut Creek, CA
    bushings, bushings, bushings ...........
    Slippery slope working on this van. Anyone have links or part numbers to replacements? Short of that I'll likely just take all of them down to FLAPS and try and find something that works.
    Name:  font swaybar.jpg
    Name:  rear sway bar bushings.jpg
    Thanks Josh
    1986 DX 5-spd
    May 2014
    Arizona
    Re: bushings, bushings, bushings ...........
    http://www.rockauto.com/en/catalog/t...751,suspension
    Not sure 100% about 4wd, but all of those parts seem to be on rockauto. Don't see any reason for the part numbers to be different from 4wd to 2wd but it's always good to run the part numbers and cross reference them somehow. Just be careful with rockauto and don't spring for the cheapest parts. I usually find parts on rockauto and then search for the same part # on amazon because with prime shipping it's cheaper and faster. Good luck.
    vancouver canada
    Swaybar Bushings,, Motor mounts,,,,Recco's?
    ...took the van into the front-end shop,, expecting to find something loose,,, turns out it's mah ass that's wiggling!
    Here's my shopping list,,, is there some place on line that's 'one-stop' for all of these?.... any recommendations of type, etc?? 1986 2WD
    Sway Bar Bushings... all of them.
    Rear Upper Control Arm Bushings
    Left Engine Mount
    Transmission Mount
    Oil Level Sensor.. works but Leaks...is there a seal for these?
    .........love it when the thing that says 'Low Oil' ...is whut's causing it ...often the same with drainplugs on boats!
    Not having much luck in archives yet......much appreciate if someone can point me in the right direction,,, thanks!
    vancouver canada
    Re: Swaybar Bushings,, Motor mounts,,,, Source?
    .....found these at Autoparts warehouse... said to be a direct fit for 86 2wd.... is there other bushings anywhere in the swaybar???
    vancouver canada
    ....this is another component of swaybar bushings, or a duplication???........
    Duplication. The small bits in the bottom of the first picture assemble into the same part. The oil level sensor has an o-ring type seal. The part number is posted on the site in a few threads you'll have to search for that one.
  8. 09-07-2017, 03:06 AM
  9. #8
    vancouver canada
    ...thanks,, is there any other bushings needed for the swaybar?
  10. #9
    Van Addict AD2101's Avatar
    Tucson, AZ
  11. #10
    vancouver canada
    ....yes,, found that when I did my hunt,,, it's labeled as for 4x4, mostly front.... not clearwhat applies to a 2wd rear swaybar.
