So the last few months I've had troubles with the van intermittently running on 3 cylinders (starts to sound like an old vw bus). When it started doing it, it would just happen every once in awhile and usually after it had been run for awhile. Then it got worse and some days it would run all day on 3 cyls and the next day run just fine. One day it stalled on me and I had a heck of a time getting it restarted. Finally got it restarted and limped it home (stalled a couple times on the way home but started up right away). Codes were all over the place, so I cleared them (I don't remember them, but I believe most of them were from trying to get the thing restarted).
I changed the cap/rotor, spark plugs, and sparkplug wires. Spark plugs, wires, and cap looked fine but the rotor looked pretty bad, so I thought I had found my problem. Van ran fine for about a week and then started doing the same thing again (damn), but it wouldn't throw a code. This week it started getting bad again and finally died on me a block from the house and would not restart. It would crank, but no spark. FINALLY, it threw a code!
Code 14 - Ignition - may be the igniter and ignition coil
circuit, or the igniter and ignition
coil
• no “IGF” signal to ECU 4-5
times in succession
Autozone had an ignition coil in stock so I picked that up and installed it. First time ever pulling a distributer, thanks to Tim's other threads/tips, I was able to pull it and get it back in and get the van started. The van now started and I was even able to drive it around and get it warmed up. It still sounds like it is running rough and has a bad miss. Ran it for about 20 minutes on the street and had it on and off quite a few times but it never threw a code.
I went and got a timing light and decided to try to do the timing. It's running rough and I had a heck of a time getting a good angle with the light on the indicator and getting my head where I could see the indicator at the same time, not to mention the thing is running rough and I had a hard time with the idle speed. I killed it a few times by turning the distributer too far and was getting frustrated with the timing light which didn't seem to be working well and it was getting dark etc... I killed it a few more times and then it got to the point where it wouldn't idle without dieing on its own. In the end, I couldn't get it to start again and I got the code 14 again.
I'm guessing I need to call junk yards today and try to find an igniter? Any ideas what years of vans would have to the same igniter as mine?
This really sucks to try to do without a manual. I'm used to working on my 4runner with my factory manuals (speaking of which, the 4runner blew a headgasket this week)
. FWIW, you are going about this the same way I would. Based on your description and the code 14 I would suspect the coil 1st and the igniter 2nd. Toyota used the same igniter (89620-28040) from 86-89, so any in this year range will work. I could be wrong, but I believe this particular igniter is specific to our vans. Here's one on eBay:
(EDIT) I just bought one of the ones Tim posted from ebay. I got the one that also came with the extra electrical book (figured that might come in handy
I could move the distributor some and get it running better, but obviously it wasn't going to be close to the 12* it should be.
. At this point I would climb under the van and clean-up the entire periphery of the crankshaft pulley with a wire brush (to make sure there isn't another notch there there covered in grime). Once you're sure there's only one well defined notch, mark it with a dot of fluorescent paint so there can be no more confusion. I would also take a good look at that new timing light of yours and make sure it's not one of those that can be adjusted to delay or advance the strobe. If it does happen to be an adjustable one, then make sure it's set to zero.
). If after that the timing mark is way off of TDC, then you'll need to pull the crankshaft pulley and make sure the woodruff key is there and intact. If the key is intact and the keyway looks good, then it means the outer part of the pulley has slipped on the rubber insulator (meaning you will need to replace the pulley). Keep in mind that it's not too unusual to have problems with the woodruff key on these. If it has broken (allowing the pulley to slip) and you run it for too long, the end result could be destruction of the crankshaft. I hope it's something silly like an "out of adjustment" timing light. Tim
) I think I will have to start with double checking that there is not another mark on the pulley, just to be sure. Then I guess I'm going to have to pull that pulley and see what I find and go from there. I'm also going to go through every test the manual has for the distributer/ignition coil with my multimeter. After that, I think I'm going to have to take a look at my ECU as well to see if there are any loose connections that could be causing the miss.
Going to make things much easier, so I don't have to walk all the way back in the house to look up the one online
, so I decided to actually use it and test the ignition coil and distributor with the multimeter like it says to.
