My van started to kind of sputter or jerk at various times, sometimes starting in first and getting speed, or while I am in 5th at high speeds I notice a high speed stutter. There is a small power loss at times, but I am still able to get it up to highway speeds.
The van is a daily driver, often 40+ miles per day on windy 55mph roads. The progression of this problem happened fairly fast in one day and has stayed about the same for the last 2 weeks. Driving throughout the day it will be worse a certain times then others, although I don't see any patterns as far as engine being warm or cold.
When I listen to the van idling from the tailpipe there will be a slight pop every couple seconds. Not a loud pop, but almost a bubble sounding pop.
There are no problems starting it and it idles fine without stalling
Van: 86, 2wd
New parts since this problem:
Spark plugs (still using the same wires, the casing looks good)
Cap and rotor
New air filter
The fuel filter was replaced about a year ago.
Thanks for any advice.
Take good care of a new one and it'll be the last one you need to buy.
