Hi all. I've had my 85 Van in and out of the shop several times in the last few months because of overheating issues. I ended up going on vacation for 2 weeks and left my van sitting the whole time. Came back and everything started fine, but seemed to run a little on the hotter side (nothing severe at this point), however as I kept driving it, it would overheat as soon as I got off the highway to my work. I brought it to my mechanic who has rebuilt the engine on this Van and done quite a bit of other work on it, and he suggested getting the radiator cleaned out and thermostat replaced. He said bottom (output) hose out of radiator was cool, so there was no circulation of fluid. He also replaced my radiator cap. So all of that was done and I took my van out, and next day it was overheating again. By the time I got it to work, there was coolant dripping very heavily from what looked like part of the frame in front and underneath the radiator on the driver's side. I filled the filler with water after it cooled and drove it back to the mechanic only a few miles away. He said he thinks one of the hoses just under the filler cap wasn't tightened enough, so he tightened it and refilled with coolant. He did a pressure test on it twice and said no drop in pressure. I picked it up and drove it for about two weeks, no problems. Then one day out of the blue, it just decided to overheat again on the way to work, just getting off the highway. I waited until it cooled and filled it back with water that night and drove it home. It lasted about 3 days until it overheated again. Waiting to cool again and filled it with water, only this time it didn't even last a whole day. The next day on the way to work, it was overheating again and I pulled it into a parking lot as soon as I got off the highway and inspected around a bit under the seat. It almost seems like the coolant is coming out of the reservoir overflow. It definitely is not leaking from the reservoir level sensor. I have actually replaced the sensor and gasket/grommit fairly recently with a brand new one and there is no sign of leakage through that. But I am thinking that the coolant coming from the overfill is leaking out and running down the frame and dripping from where I saw it leaking originally. At this point, I was so fed up, I just called AAA and had it towed back to my mechanic. Now it is in the shop again, he's doing pressure test on it and still can't find any leaks. Are we missing something here? I am getting super desperate to figure out what's going on and he can't seem to find the problem either. Is it possible that the system and actually push out too much coolant out of the coolant overflow so that it doesn't even have enough left to cool it? Each time it overheated, you could hear a strong bubbling sound coming from the reservoir tank as if the liquid was boiling. Could too much pressure by building to force it to act in a different way? I'm all out of ideas and I've checked a around on other threads here and nothing seems to address it very specifically.
