- 0
Previa Lift install
I installed a lift on the previa after getting motivated by Tim and Mountainhick. I wish Journey off road would have had their lift kit sorted out when I started this project rather than rely on my shoddy workmanship.
So, I installed my 2" spacer. (not sure if my pic will show up, trying to figure out how to post pics)
I lowered my front differential using the same method as Tim and installed a 1/2" bolt in the top hole of the lower strut mount to accommodate camber issues.
Now here's my issue. When I removed the jack stands and put the tires back on the ground, the lift was almost 4 inches and had a massive amount of positive camber.
The front suspension seemed to settle in when I backed up and moved the van 20 feet or so.
Then after my first test drive, the camber was really bad again and the lift was back to around 4". I've checked everything that I can think of and this scenario was repeated several times.
It seems to settle when I drive straight but after a tight turn the camber is really bad again. Anyone have any ideas for me?
