Hey there, havnt posted in a long time, the van has been running well till lately...
86 5 speed, was running normal, shut it off for 45 min. and then upon start up an instant change. shuddering and loss of power. as I drove it home @10 minutes, it got worse, till I had to tow it. codes were 5 and 11. replaced the o2 sensor. got rid of 5, found the plugs extremely leaned out and the coil burnt up (coincidence with the coil ?) replaced, no change.
I am still getting a code 11, TPS, It starts up and runs great for @ 15 seconds but then really bogs down and I can barely keep It running. I left the neg battery terminal off for a minute, and before starting checked to see if code was clear, but it was still there, left the neg terminal off all night and this morning without turning it over checked and it is still there? is that normal, I thought the codes would clear untill the van was run again?
thanks
josh
