Results 1 to 6 of 6
Thread: Ecu location and idle rpm box smoking
    1984 toyota van wagon 2.0 2wd
    Aug 2015
    Fallon nv
    I'm new to this website but excited to be on here. I am confident I blew the computer ecu/pcm in my 1984 toyota van. I smelled smoke and my rpm box is making all my relays go haywire on off constantly if I tap it or wiggle it its worse also i see blown capacitors and resistars I know the ecu is probably the same but I need help pinpointing where it hides I've got the dash all out and don't see it
    thanks a ton,
    Dustin
    Re: Ecu location and idle rpm box smoking
    The ecu is mounted down low in the left(driver side) "B" pillar behind the seat belt retractor.
    Aug 2015
    Fallon nv
    Thankyou a ton I would have never looked there in a million years
    1985 2wd Manual LE
    Mar 2015
    United States
    How does one go about removing the plastic panels to get to the ECU? I don't want to break these panels trying to pry them off.
    Hers a inside picture of the left side panel that should help-
    1985 2wd Manual LE
    Mar 2015
    United States
    That should help. Thanks so much. Now I know which way to slide it off of those plastic fasteners, at least.
