I have a '93 Previa. I've read that there was an updated design to the SADS drive shaft beginning with the manufacturing date 01/94. I've seen recommendations for just getting a newer driveshaft and using the newer coupling kit, while I've also seen elsewhere about just getting a coupling set for the old design. I'm hoping some of the Previa gurus can chime in here. What exactly is different between the old and new designs for the SAD shaft? Is it just the 94 and newer bushing holes are 14mm OD, while the 91-93 bushing holes are 12mm OD? Is there anything else different that make the newer designs better?
