Hi All.
I am slightly confused about the timing marks as I am changing my timing belt. I have the manual, and have set the cam shaft timing pulley, the injection pump drive pulley and the crank shaft pulley as shown in second diagram down on the page attached.
My issue is I don't really understand the crankshaft timing pulley. In the diagram on the page inserted below, it looks like the pulley gets aligned with a notch at about 1 o'clock? But there seems to be conflicting information on ace answers...
cam- notch on pulley level with surface of head, 3 o'clock.
pump- notch in line with groove on face of waterpump housing, 2 o'clock.
crank- notch on outer of fanbelt pulley with tapered pointer, 8 o'clock.
Could anyone who has done this help to clarify? Also, does the oil pump drive pulley need to align with anything?
And, in the third diagram down on the page below, is the manual describing and alignment with marks that are actually on the timing belt?
Thanks in advance!
Matt
