Results 1 to 1 of 1
Thread: intake build up
    92 previa
    Louisiana
    intake build up
    heres the area inside intake
    theres definitely a port hole clogged...
    is this circulating in or out of intake?
    is there a line with this buildup needing
    cleaning/replacing that is
    leading to or from this hole?
    I m slowly cleaning it best i can
    hard to reach/see (using mirror/ dentist pick)
    just found numbers for rubber ring gasket
    to throttle/idle air controller 22271-76010...
