Results 1 to 4 of 4
Thread: Code 4
    Van Fan Tan Van's Avatar
    1987 Van 2-wd
    Sep 2014
    Milwaukee, Wis.
    Code 4
    I broke my water temp sensor while changing the cap and rotor ... ...meanwhile, I got a check engine light with codes 4 and 5 ... I replaced the broken sensor with one from Rock Auto and cleared the codes... but -the check engine lite is still on , and now I still get a code 4 .... I've had the van for 13 years with NO check engine lites-- QUESTION ... could the new sensor be bad ??? ( If it matters, my temp. guage is working properly...does the guage run off of that sensor??) thanks !! - Phil
    Re: Code 4
    Lots of threads on this subject. I did a quick search and found this one: http://www.toyotavantech.com/forum/s...Codes-4-and-11
    The gauge sender & the ECU temp sensor are 2 different things. The one you need to clear code 4 is the ECU sensor shown in that thread. Good luck. Tim
    1987 Van 2-wd
    Sep 2014
    Milwaukee, Wis.
    Re: Code 4
    thanks ... I'll start by jiggling the plug on and off on the ECU temp sensor ... I'll run it awhile, then clear it and look for codes again ... --QUESTION ... If the ECU clears up and has no codes, will the check engine light turn off by itself ?
    Re: Code 4
    Once a code is recorded it will remain until cleared. To clear you must pull the EFI fuse or disconnect the battery for a minimum of 15 seconds.
