Hey guys, anyone know if the injectors from a 4Y engine are interchangeable to a 3Y Engine? My van recently stopped firing in cylinder 3, I have spark and compression but no go. Any Knowledge would be appreciated!! thanks
Here's a quote from another thread to help determine which cylinder is giving you issue:
With few exceptions, injectors are the same from 84 - 87. 88 - 89 injectors will physically fit the manifold, but the connectors (for the wires) are different. If you go to all the trouble of removing the upper intake for access, I would recommend taking them all in for cleaning & testing. Be sure to check your injector connectors as the van is hard on these (trapped heat takes a toll). It's not unusual to see a damaged wire or one pushed out of a plug.
Last time I had a problem with an injector I was lucky enough for it to be #2 (easy access). I was able to pull the connector and apply voltage directly to the injector (to verify it was drawing current.........it was). Next I rotated the engine so #2 intake valve was open & removed #2 spark plug. Next I put an inspection camera down the spark plug hole & activated my fuel pump. With fuel system active I put power to the injector and verified with my camera that there was no spray.
I'm not sure if you have the ability to test like this, but I feel a lot better pulling things apart when I know for sure it's necessary. In my case it was already a new injector (had never been fired). It was probably stuck from sitting on the shelf. I tapped on it while applying/removing power & it finally started working (thank God). Having an inspection camera isn't necessary, but it's nice being able to verify fuel spray entering the cylinder. Before I had my camera I used Engine Ears and could hear injector spray entering the cylinder. Anyhow, in my case, after that injector started firing my van has been running awesome & hasn't missed a beat since (I've put 3k miles on it now). Tim
PS: You can also test injectors 3 & 4 like this, but it requires you to gain access (electrically) by opening the wire harness.
Tim what is the voltage that needs to be applied to activate a fuel injector?
I used 9 volts to clean my injectors. Short spurts.
I heard(internet) that you shouldn't use 12v.
I've always used 12vdc, but only in short spurts (like 2 or 3 seconds). It wouldn't surprise me to find out you're not supposed to do that, but I do a lot of things I'm not supposed to. Tim
If you look over the schematic there is a set of resistors before the injectors... So I would assume 12vdc isn't the right amount... But I'm still not sure what is, and in short burst they can't do much harm.
In my case, perhaps it was the shock of 12VDC that jolted my lazy injector back into action.
