Results 1 to 20 of 38
Thread: Heater woes
Threaded View
  1. #10
    '86 2wd
    Mar 2012
    Salem, Oregon
    Re: Heater woes
    Greetings fellow Snowpocalypse 2.0 survivor. My van is parked in what is now down to 6 inches of snow in front of my house.
    If you have no blower action, first thing you have to do is check / reset the breaker and go from there. Usually, though, when a fuse blows or a breaker trips, something causes it. Fuses rarely blow just due to old age- something drawing higher-than-spec amperage causes them to blow. So look for bad fuses / tripped breaker, replace or reset one that's blown, and if it blows or trips again, suspect either a wiring problem or a failing fan motor (or something impeding the fan motor's rotation).
