3CT Lower Radiator FAN SWITCH location question
Hi All,
I have a 1993 3CT van and I cannot locate the thermal switch that operates the fan attached to the lower coolant radiator. If anyone knows where it is , please let me know. It is definitely not up on the hot water manifold on the top of the engine on the driver's side....
Thank you!
Kara
- 0
Re: 3CT Lower Radiator FAN SWITCH location question
I don't know where it is. But I'm following your posts, as I also have a 93 with 3CT. I tried to take it up a steep mountain grade, pushed her too hard and over-heated. Since then I'm been worried about the cooling.
