Results 1 to 6 of 6
Thread: LED Dash and Brake Master cylinder change, or not?
    1987 4WD LE
    Jan 2021
    CA
Size:  83.0 KBThrough TVT friends here and posts on how to remove the instrument cluster, I changed out the dash bulbs to white LEDs, here's a photo attached.
    Also I got into the dash to inspect my master cylinder and need some opinions if I should change it out. The brakes seem to grab fine, although they pull to the left when it is pressed hard, but I saw some fluid on the floor mat. It was dark, but it was not the color in the reservoir golden brown. I was contemplating changing out the master, but not 100% if I should. I am not familiar with changing it out, but would be a complete swap and bleed?
    I am attaching some pics to this and appreciate any input.
Size:  98.9 KBName:  IMG_20210402_185004088.jpg
Size:  98.3 KBName:  IMG_20210402_203941578.jpg
Size:  95.4 KBName:  IMG_20210402_195943394.jpg
    Re: LED Dash and Brake Master cylinder change, or not?
    Wow LED’s look great, which bulb size/brand did you use?
    1987 4WD LE
    Jan 2021
    CA
    JDM- my apologies for the huge photo, just realized that! Not sure how to resize it. For the LEDs, I used the Serundo Auto I found on Amazon: https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1.
    JDM- any thoughts on my master cylinder issue above?
    Thank you for the link, as for the Brake Master I personally had mine replaced when it started leaking on my shoe, it hadn't failed completely but I didn't want to take any chances. Sorry I had taken it into the shop so I don't have much to offer except a couple of threads that have covered the topic-
    https://www.toyotavantech.com/forum/...t=brake+master
    Check out those threads and post in one of them and you'll probably get a quicker reply. Good luck!!
    1987 4WD LE
    Jan 2021
    CA
    Thanks JDM for the help and the links to the post!
    Sep 2016
    SoCal
    ive had great success with LEDs from amazon, they make a huge difference.changed ALL interior lamps in 3 vehicles! when you change the MC, consider replacing any flexible lines.
