![Quote](images/misc/quote_icon.png)
The lower temp switches were only available for this service bulletin campaign (see PDF file attached to this post) and are now NLA (No Longer Available).
If you think about it, the normal operating temp of the engine is about 195-205 deg F (in the switch location), so this means the new switch will activate the "pressure up" mode of the fuel injection system almost every time the van is started (unless the van has had over an hr to cool). Because of this, I think it's reasonable to assume it wouldn't hurt for the "pressure up" mode to be activated on every start (including cold ones). This can be easily achieved by simply cutting the wire off of this sensor and attaching it to ground.
