Misfire underload and misfire when cold toyota 3y
Hey guys,
just recently bought a hiace. When cold it has a misfire in cylinder 2 at idle, it also has a slight misfire or hesitation when under load and is worse when it colds and slightly noticeable when it's warm. It has spark, fuel, no vacuum leaks and good compression. It doesn't have oil in the coolant or vice versa. I took it for a drive up the range and could only make it up half way as it started to buck pretty badly when under extreme load. Luckily for me I drove back down the mountain and drove home.
I have replaced the leads, dissy cap, rotor button, fuel filter, air filter, checked plugs(which are fine).
Re: Misfire underload and misfire when cold toyota 3y
Is this fuel injected or carbureted?
When the engine is cold you can remove the lead from the spark plug and it doesn't change the way it runs. When the engine is warm it doesn't miss at idle. I changed the plugs around and leads and have isolated the cold misfire to cylinder 2
Well, that rules out plugs. Did it do this before changing the cap and wires?
Yeah I went for that drive before I replaced those said parts. I found one of the leads had high resistance, fuel filter still had Japanese writing all over it and was semi blocked, air filter was pure black, dissy cap and rotor button were quite suspect.
To Be honest I have been a bit offish to take it for the same drive due to it being 2hours away and it was more then frustrating the first time.
When you pull the wire on #2 did you verify spark on this lead during the misfire? If there's spark there, then I'd probably check the float bowl on the carb. Make sure the float level is adjusted correctly and verify the bowl is clear of water and/or debris.
Yeah there is definitely spark there. I'm a bit of a newbie when it comes to carbs. If it were the carb though shouldn't effect all cylinders?
Yes, but it's the under load part that points to possible float issues or contamination in the float bowl. It might be a 2 part problem.
Yeah I have thought from the state of the fuel filter that the carb would be the same. It's strange that when the engine is cold I can remove the lead on that cylinder and it stays the same(misfires) but when I do it when it's warm it changes.
The misfire under load is frequent but not rhythmic(is intermittent).
Yes, if it's a fuel issue, with a carb they should all be the same, but if it's a marginally lean issue, depending on manifold runners, atomization, etc, one cylinder may be affected slightly more than the others. Hard to say really, just grasping at straws. Do the plugs look white or tanish around the electrode area? Does #2 look any different (color wise) than the rest? Tim
All look the same, did notice when I was doing checks that the number two plug was wet.
FYI, We don't have carbed vans in the US. Everything here is fuel injected. I have however had some experience with other carbed vehicles. Had a similar problem on an old Corolla years ago. Turned out to be a bunch of junk in the carb. Yours is a little different though. This one ran good at idle (hot & cold). Tim
Assuming that's been run for over 100 miles, that looks good. Shouldn't be wet though. That indicates a possible spark issue. If you have an inductive timing light, put it on that wire while it's missing to verify a consistent spark. Tim
Lucky you guys. Well I'm going to do a leak down test asap just so I can rule out the valve train/head. Thanks for your advice, I'll give the carby a good clean the following weekend when I get some time off.
Cheers Matt
I put one of those spark testers inline when I was testing them. It looked like it had a consistent spark.
Good luck. Let us know what you find out. Tim
I was thinking that the coil could be the culprits but then again it should effect all cylinders
Yeah, I considered that briefly but discounted it. You never know though. Sometimes weak ignition parts can have more effect on some cylinders. Coils are cheap here (not sure about over there). Sometimes I'll just swap stuff to rule it out. Does your van have ignition points or does it have an igniter?
It's built into the dissy, so I'm guessing it's an igniter. They're about $50 over here, all this maintenance spending is cutting into my camping gear purchases lol.
To be honest I plan on doing an engine conversion later down the track so I don't want to go to the extent of rebuilding and replacing everything on this engine. Well the things I don't have to at least
so I managed to get the specs for the coil so I decided to test it. The secondary side was reading 2k ohms out of spec, I hope this is the culprit. Tim do you think that it could be?
These things hardly ever test to be within spec. As a result I quit testing them. If I suspect a coil I just replace it. If the problem persists, then I know it wasn't the coil. Coils are cheap though, so no great loss if that's not it. Tim
I was just thinking that if one of the ht leads was faulty, maybe it could've caused the coil to fail. I know it's not greatly out of spec but to my knowledge the resistance obviously increases as the coil warms up.
With old cars it's just a good idea to have some "known good" spare parts around............especially the critical ones. If you replace the coil and the problem persists, there are still 2 positives: 1. You now have a "known good" coil in you spare parts kit. 2. You know your problem wasn't the coil. Sometimes troubleshooting is simply the process of elimination. Having extra parts around can save a bunch of time. Once you know a part is bad, throw it away. Nothing worse than having a bad part laying around...........especially if it gets confused with a good one. Tim
Instead of just buying one and giving it a go, I'm going to borrow the one off the forklift at work and test it in mine. The only thing is I have to find the right opportunity when my boss isn't there lol
Not sure I'd risk my job for the price of a coil...........unless you don't like the job. When I've had the choice to extract one from a parts van (in my back yard) or go to Napa, I chose Napa. Not sure what they cost down under, but here in the US you can get them for under $15 (with free shipping): http://www.ebay.com/itm/NEW-IGNITION...63f563&vxp=mtr
I envy how cheap everything is over there. They are $50
in Australia
Okay so my results for the leak down test are that cylinder 2 is at 35% which is just out of range. I also put gas into the cylinder and found that the gas was coming out of cylinder 3 when I put it down cylinder 2. This is making me believe that its a blown headgasket.
i have a couple of weeks off over xmas so I'll remove the head then
Hi all :) I would be interested to hear about any updates? :)
