technocj
No problem, Tim, I always say, ''I thought I made a mistake once, but I was wrong''. I will get back at it as soon as i have time. I wish I had complete confidence in the set up of the TPS. I changed out some old vacuum hoses today, did not find any that were visually cracked. Next will be to inspect the rocker arm for correct assembly.
After eliminating every possible problem, other than injectors, I back tracked, removing the upper intake. I read the post regarding removing material from the head surface, and taking a like amount of material off of the valves. I had the head serviced while it was off, by a very good shop, I did not tell him the valves were not adjustable. I visited him today, he does not recall how much he might have shaved the head. I removed the head today.
My options as I see it: ask him to take .002 or .003 off the valves, he doubts he would have taken more off. Purchase a new head off E-bay. What do you think? I was also thinking of removing the fuel injectors and have them checked, and replace the harness,the connectors are not in good shape at all. Auto Zone now sells pigtail connectors for about 7 bucks each. What is the trick to removing these connectors without damaging them?
The van is really in great shape, I can't give up on it, it's a cargo with no side window.
