JDM VANMAN
Thank you for the quick response!! The OEM cap is 4 years old and about 30k miles but as for the ignition coil don’t think it was replaced when I originally had a ton of work done when I first got the van??
I’m thinking that has to be the issue!!?? I checked on RockAuto and there’s about 4 different kinds, is there a “part of choice” you would go with or should I order an OEM part?
JPERL,
Thank you for the response I think I’ll be starting with replacing the coil and keep my fingers crossed!
Thank you:thmbup:
