Re: Replacement speedometer cable?
Hello,
I've got a 1987 Manual 4WD LE with a cable that snapped about a 1/3 of the way from the speedo to the transmission. I'm in Vermont and salvage yard finds are scarce and there aren't any local speedo shops. Does anyone have a spare they're willing to sell or trade for? If not, any suggestions on where I might be able to get a custom one made? Thanks!
I found a cable from a junk yard, but when I went to install it I realized the place it attaches on my transmission doesn't look typical. It looks like it needs a cable with a male threaded end. The van is an 85 le. Has anyone seen this?
pic: https://drive.google.com/file/d/1Cku...ew?usp=sharing
I had the same issue in my 4WD 5 speed cargo van, the threads on the Speedometer Gear Sleeve were broken but luckily the cable was not damaged. I ordered 3 complete sets of Speedometer Gear, Sleeve and clips and bought a used one from a TV member. The S/G is NLA in the U.S.
https://i.imgur.com/GDlEL9e.jpg
https://i.imgur.com/D607x9U.jpg
Comparing the splines from the used S/G to the new one
https://i.imgur.com/nYXHTfu.jpg
https://i.imgur.com/N5CitEx.jpg
It looks like the threads on the sleeve is broken which are still available last time I checked.
