Re: Fuel filter or injector?
As I recently learned from a previous poster with a similar issue, not everybody checks the oil.............so I'll start out by suggesting that. Based on your description I wouldn't suspect an injector. It does match the symptoms of a plugged up fuel filter though, so I would suggest replacing that. Even if it doesn't fix the issue, it's most likely over due anyhow. Another thing that matches the symptom is a plugged up cat converter. When a cat plugs up, it usually overheats & causes heat damage to the EGR modulator, so check this for signs of heat damage. The cat can be tested by temporarily disconnecting the inlet side from the exhaust and rechecking the power situation with it wired out of the way (so exhaust can exit before the cat). It will be loud, but it's just long enough to verify.
There are more things that can cause this, but these are the two main ones (3 if you count being out of oil :dizzy:). Tim
Thanks, good to know as I'm getting ready to bring it home from work I'll bring some oil with me just in case, But the cat convertor may be it the van did sound like its exhaust had an issue almost like it was a little blocked up I'll report what I find this afternoon.
When I went to check the oil level I moved the power steering hose it was dry rotted and broke off in my fingers proceeded to check oil it was full and barley dirty finely some good news, replaced the power Steering hose with irrigation hose just to get it home and fired it up to my surprise it didn’t bog down on the way home but I stopped to fill up with premium it only took 4 gal but I wanted to get as much good gas in as possible sea foam worked great after filling up van would not start had to tap on the new starter he put in it was hot (any starter suggestions) when it started the fuel gauge moved all the way to full another positive I’ll take all the little blessings I can get, got home checked codes I got 6 steady blinks followed by 11 steady blinks I’m guessing this is good because I can’t find any trouble code to match I’m heading out to get new PS hose and fluid any comments are appreciated thanks Ralph
